I use a macbook pro with virtual dj and m audio conectiv.
According to the forums, people say it works great with virtual dj,
but when I use it, BOTH decks on virtual dj only play on ONLY channel 1 of the mixer, and channel 2 has no signal...
Basically, I just want deck 1 on VDJ to play on channel 1 of the mixer,
and deck 2 on vdj to play on channel 2 of the mixer, so I can actually start mixing!!
PLEASE HELP!!!!!!!!!!!!!!!!!
Posted Thu 29 Oct 09 @ 2:42 pm
Go into settings on VDJ make sure that you have it set for two TCV and external sound card which should say M-audio. That should do it. I use it all of the time.
Posted Thu 29 Oct 09 @ 3:02 pm
and make sure your "Output's" setting is set to External Mixer
Posted Thu 29 Oct 09 @ 6:28 pm
Ok so my settings are:
Inputs: None
Outputs: External Mixer
Soundcard(s): 2 Cards
Driver 1: Conectiv
Driver 2: Conectiv
Output Channels: Left Deck: First Card / Right Deck: Second Card
Is there anything else I should change in the settings?
Problem: Both decks still play thru channel 1 on my mixer... I thought it was a problem on my mixer, so I tested it on a djm 400, with the same problem...
Inputs: None
Driver 1: Conectiv
Driver 2: Conectiv
Posted Thu 29 Oct 09 @ 7:10 pm
Wait. Since you have turntables the settings should be:
Input: Timecodes
Output: External Mixer
Soundcard: ASIO Driver
Try that.
Input: Timecodes
Try that.
Posted Thu 29 Oct 09 @ 9:19 pm
Oh, I'm NOT using turntables by the way...
only macbook pro with VDJ, m audio conectiv, and a mixer.
i still need help!!
i still need help!!
Posted Fri 30 Oct 09 @ 12:03 am
I am not sure how you have selected 2 soundcards. If you have the latest version, settings with conectiv should be
EXTERNAL MIXER: Left Deck Chan 1&2 / Right Deck Chan 3&4
SOUND CARD: Asio Driver M-Audio USB ASIO
or maybe its different for Macs
Posted Fri 30 Oct 09 @ 4:13 am
Are you saying that you get the same problem with the DJM-400's...?
If so then it can't be a VDJ issue. Does the mixer have a channel assign for the crossfader? Make sure that the left side of the crossfader is set to channel 1 and the right to channel 2. Otherwise it will be unassigned and will heard unless you kill the volume for that specific channel.
Cheers,
Roy
Posted Fri 30 Oct 09 @ 7:03 am
Yes, I've tried it with a DJM400 as well, with the same results... deck 1 and deck 2 playing on channel 1 of the mixer only...
More help needed please!!!!
Posted Fri 30 Oct 09 @ 3:59 pm
How do you have your cables joining things together?
Posted Fri 30 Oct 09 @ 4:07 pm
i have it connecting just as you would to Rane Serato
im sure the connections are correct... this is really frustrating.... arghhh!!!
Posted Fri 30 Oct 09 @ 7:34 pm
More HELP is NEEDED!!!! thanks! :)
Posted Sat 31 Oct 09 @ 2:58 pm
What version of VDJ are you using?? I'm using the conectiv and never had this problem..
my current settings are:
Inputs: Single Timecode (but yours will be none)
Soundcard: ASIO - M-Audio USB ASIO
I would also suggest going into your computers sound settings and make your onboard soundcard the primary soundcard... this will make sure other sounds from your laptop aren't playing through your conectiv
to help further maybe you could post some pics of your setup
Posted Sun 01 Nov 09 @ 6:00 pm
and it could be a mixer issue as mentioned above... what kind of mixer are you using??
Posted Sun 01 Nov 09 @ 6:02 pm
i cant get my conectiv m-audio to work with virtual dj i am use 2 turntable mixer toshiba laptop my music is coming like its draging
Posted Fri 05 Mar 10 @ 10:50 pm
You will need to experiment with the performance settings. Untick safe mode and overclock - try moving slider towards fastest. Adjust latency to 256. You have to adjust these settings for your computer speed.
I have a quad core 2.8 with 4 Gb of ram running vista (9600GT Vid Card - directx 10) and use 128 (2ms) Latency with Enhanced Algorithm and Lowpass filter set to 35 with Filter Smooth ticked and fast master tempo (if I set Advanced master tempo, I get audio glitches). Runs great with cd timecodes and multiple video effects, etc.
Posted Fri 05 Mar 10 @ 11:13 pm
