Greetings,
I"m stumped. I have a pair of the Q-Spot 150 LEDs and can't get the light to turn on in DMX 512 mode.
I'm just learning this DMX world. I just cannot find a way to turn these on under DMX control. Test mode, Auto mode, and Audio mode work fine on the units. It's just that in DMX 512 mode I can't figure out how to turn on the LED.
I have the unit set for BASIC and I'm using PC software DMX Lightplayer and FreeStyler with a Velleman VM116.
I have pan and tilt control. I can see a small light inside the lens and can see the gobos change, and spin. I can see prisim movements. I think I have all control but just can't get the LED light to turn on.
Is there a blackout control I need to un-do, or a command on a channel? I'm stumped and would appreciate your help.
Regards,
Jim L.
UPDATE: I can use Channel 9 to select my Auto, Sound, Test modes from the software, and I have LED light from the fixture. I just need to figure out how to turn on the LED without being in a built-in program. I gotta be close !
Regards,
Jim L.
Posted Mon 26 Oct 09 @ 2:57 am
How new exactly are you to DMX and stuff? New enough to not know shutter? Else I would check your personalities. :)
Posted Mon 26 Oct 09 @ 5:01 am
have a look at this clip found on youtube if this helps lot on there i don't have is one i run martin lighting joc i found it a lot better and most clubs have it .
http://www.youtube.com/watch?v=_CJgmjyM9Os
Posted Mon 26 Oct 09 @ 5:19 am
Check your Blackout button on your DMX controller or software. IT may be activated without you realizing it.
Posted Mon 26 Oct 09 @ 9:12 am
Ahhhhhh..... I feel better now.
I called Chavet Tech Support. My trouble was with Channel 8. They have it in the manual that this is the "Strobe" channel. When I opened the "Strobe" to a #33 ( open range is 32-63) the LED came on solid. Oh, actually I see it will open with 3 other value ranges. The wide open strobe #224-255 works also.
Kinda goofy way to hide the light switch. To me strobe means "flash" not solid "on". My mistake.
In summary... To turn on this light use channel 8 "Strobe" and use any value called "Open".
Thanks guys for the help. This trouble is resolved.
JimL.
JimL.
Posted Mon 26 Oct 09 @ 12:55 pm
Look through the menus on the light. You will need to enable DMX mode. You can find this information in the manual BTW. Good luck!
Posted Mon 26 Oct 09 @ 2:04 pm
The main problem I have is that the software has the wrong settings to match the Q-SPOT 150 LED configuration.
Like with Freestyler. I select the Q-SPOT 150 from the device list, but when I click on a color in their colorbar the gobos spin...that's not right.
Obviously the Freestyler is not setup to match the Q-SPOT's channels. You would think Freestyler would have set this up properly when they even have a nice picture of the device to select. But the settings do not match.
To figure out this mess, I just ignored the labels on the screen and found that the light responds exactly how the channels are set up in the Q-Spot 150's documentation. I just have to now customize the settings to the light. Hopefully I can.
Thanks,
JimL
Thanks,
JimL
Posted Mon 26 Oct 09 @ 4:13 pm
