can i use this card for timecodes vinyl? or do i have to use the audio 4?
audio 2
http://www.djdeals.com/nativeinstrumentsAUDIO2.htm
audio 2
Posted Sun 25 Oct 09 @ 5:53 pm
No you can't
You can use Audio 4 or Audio 8, audio 2 has not enough LINE INs to be use with timecodes.
I prefer Echo AudioFire 4 if there is an available Firewire port in my Pc.
Posted Sun 25 Oct 09 @ 6:12 pm
I have the latest version of VirtualDJ installed on my PC and tried using the Native Instruments AUDIO 2 DJ Interface for the first time and noticed frequent "hiccups" during songs being played. The mp3s play perfectly fine without using the interface, and I'm looking for any suggestions on how to resolve thsi problem.
Thanks!
Thanks!
Posted Sat 10 Sep 11 @ 1:41 pm
Skipping, stuttering, crackling and other sound break-up/glitches are caused by performance issues with your computer and/or incorrect configuration in VirtualDJ.
For a list of common causes and their solutions, please see the following pages:
PC: https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
Mac: https://virtualdj.com/wiki/Common%20Mac%20Performance%20Issues.html
Posted Sat 10 Sep 11 @ 5:08 pm
down grade your driver until you find the one that works... also be aware that there are two models now, the "traktor audio 2 & "Native Instruments audio 2", they both use different drivers, that was the mistake I made when downloding off the Native website.
Posted Sat 10 Sep 11 @ 5:18 pm
I really appreciate the help, and I can't wait to get this straightened out!
Posted Sun 11 Sep 11 @ 1:20 am
