To all of my VJ's out there, I'm looking for some software that will allow me to make a slideshow of pictures for a gig that I have coming up. I plan on using my MacBook for the audio and then was going to use my personal laptop to broadcast a slideshow of the birthday girl to my plasmas. I saw this done at a party I was at last weekend and it looked amazing and very professional. My everyday laptop is a dell with windows vista. Any suggestions?
Posted Sun 25 Oct 09 @ 8:08 am
There are several good programs out there that will make professional looking slideshows. I've used, Nero, ProShow Gold, and Roxio Creator. Of these three programs I prefer Roxio Creator, it has a ton of features (including making slideshows.) My version is a couple of years old, I'm sure the updated software is probably even better.
http://www.roxio.com/enu/products/creator/suite/overview.html
A quick comment about Prohow Gold (Photodex Corporation) I purchased this program for about $80 dollars and shortly afterwards the company updated the software. They sent me a promotional E-mail offering me the newer version with a whopping $10.00 dollars off coupon for the update. (They wanted $70.00 more dollars for the update)
I basically told them to KISS OFF, and NO THANKS. Although it's good software I can't recommend it for this reason. (Compare that with ATOMIX who's been giving all registered users FREE UPDATES for years)
There IS no comparison.
R~
R~
Posted Sun 25 Oct 09 @ 8:45 am
why not use the vdj slideshow plug-in along with the random effect video transition? combine that with the text2d or sbdj scrolltext, and you have a slideshow thats customizable on the fly. as long as the picture files arent memory hogs (would make an older system a little balky)all you would have to do is have it running with the delay set to your preference.
Posted Mon 26 Oct 09 @ 1:20 am
Country, there's nothing wrong with the VDJ plug-in and the price is certainly right but it doesn't offer the flexibility or professional results as would a stand alone program. With these programs you can create video files using a multitude of formats, everything from high quality Mpeg2 to Mpeg4 and everything else in-between. You could also give the slideshow to the person(s) it was created for or post it on a website etc.
I played around with the VDJ plug-in and had some trouble with it stretching photos out of proportion and it was somewhat time consuming trying to get the photos the correct size for proper display. Again it's a nice plug-in to have but depending on how professional you want to go it doesn't have all the bells and whistles one might want.
I put this example together in about 5 minutes for a demo of the effects available. (Grabbed a bunch of my animal friend photos just to have something to display) You can also add text to the photos with a lot of nice special effects which I didn't do here but the option is available.
http://home.comcast.net/~thirdrock/Test.mp4 (33 meg file)
Posted Mon 26 Oct 09 @ 7:43 am
Dj Renee, Thanks for the help. I'm probably going to go with the Roxio software. Thanks again for the help!
Posted Mon 26 Oct 09 @ 12:05 pm
There's a fix for that :)
Posted Mon 26 Oct 09 @ 2:33 pm
Scott if you can direct me to the "fix" I would appreciate it, I do like having the plug-in as well but it was stretching my head and boobs which are BIG ENOUGH as it is....
Thanks :^)
Thanks :^)
Posted Tue 27 Oct 09 @ 2:30 pm
LOL!
https://virtualdj.com/addons/4225/SBDJ_SlideShow.html
There's a nicely improved version in the works - and I'm working on transitions other than the simple fade effect.
Posted Tue 27 Oct 09 @ 4:31 pm
Thanks Scott, look forward to seeing the update, I know you have had a LOT on your plate in the past year and I hope next year is a GREAT one for for you. :^)
Posted Tue 27 Oct 09 @ 4:43 pm
Thanks Renee, I hope so too - although recent events don't point to that being the case :(
Posted Tue 27 Oct 09 @ 4:47 pm
