Hi, I have just bought Hercules Steel DJ Control.
I have Virtual DJ 6.0.1 Pro running (on XP).
Most of the buttons are not assigned to anything. Buttons 1-6 and 7-12 don't do anything (except for 1, 4 and 2).
Also, the Control 1 and Control 2 don't work all the time. For example, if I have Flanger effect on, I want to be able to change the Volume and Delay using the Control 1 and 2 Knobs. It doesn't work. I can only get the knobs to work on Loop Out, when I want to change the length of the loop.
I've researched "mappers" but it all seems really complicated. I'm not good with coding. Is there a file I can download which has all this done?
If I have to write the code myself, can someone please help me! How can I get the Control knobs assigned to effects parameters.
Thanks!
Thanks!
Posted Wed 21 Oct 09 @ 6:01 pm
You should update to the latest version 6.0.2 just to be shure that we are talking about the same thing.
Greets, Heiko
Greets, Heiko
Posted Thu 22 Oct 09 @ 4:24 am
There must be a solution to 6.0.1
Posted Thu 22 Oct 09 @ 8:39 am
Normaly you assign 'effect slider 1' and 'effect slider 2' to the knobs - that's it.
Don't know why it did not work for you.
Greets, Heiko
Greets, Heiko
Posted Thu 22 Oct 09 @ 4:19 pm
