Hi All,
Is there a way to configure the RMX so I could control the volume of the Monitor Speaker?
thanks,
thanks,
Posted Wed 14 Oct 09 @ 2:17 am
No. You have to run it through an external powered monitor like I do using a Y-adapter or at another club I run it through the main mixer & use the booth monitor volume on the main mixer. Hope that helps. Maybe not the answer u wanted though lol fellow hoser!
Posted Wed 14 Oct 09 @ 2:36 am
I use jack to jack from 1 and 2 jack outputs on my rmx to go to 2 channels on the mixer, I then use a phono lead from 1 and 2 phono outputs on the rmx to the monitor that way the monitor adjusts in volume for each independant channel so you can hear if its the same or louder or quieter
Posted Wed 14 Oct 09 @ 3:10 am
Yes, that's exactly the way I'm doing it now, was expecting something that could... change the MIDI settings or who knows, lol....
Thanks for the answers, will continue my hustle then hahahahahaha.
Posted Wed 14 Oct 09 @ 4:45 am
