We run a new HP Touch wth Vista 64 and Virtual DJ Pro. Having some glitches now...songs cutting out for a millisecond, popping...all random. We also use the Denon 4500 with it's built in ASIO driver. Anyone else having similar experiences or know any fixes or tips to get things running smoother and stable?
Thanks in advance,
Tom and Gary
Perfect Sounds
Thanks in advance,
Tom and Gary
Perfect Sounds
Posted Sun 11 Oct 09 @ 11:15 pm
Sounds like you might have a driver that is messing with your VDJ program trying using the link I have below if you see any red spikes it means your pc is using more resources than it should I had the same problem I just pause the checker and open the device manger and disabled a driver and boom it works perfect now....Here is the link.....http://www.thesycon.de/eng/free_download.shtml worked for me like a charm!
JUST BE SURE TO NOT UNINSTALL A DEVICE ONLY ENABLE......
Posted Mon 12 Oct 09 @ 7:35 am
Thanks man...I'll give it a shot.
Perfect Sounds
Perfect Sounds
Posted Mon 12 Oct 09 @ 8:26 pm
Just check if you have a lot progams run too... On start up .....
Posted Tue 13 Oct 09 @ 3:07 am
