Hi all,
I've been using my RMX for over a year now on WDM and as I have now flightcased it and run it through my Q-SD mixer as seperate channels I had to change the config.
Not really played with AISO up until now, but whilst in the process of changing my setup I thought I'd switch to this mode.
All seems to work well, however have only listened through headphones, won't be able to hook it up proper until I'm in the club tomorrow.
What do I need to be aware of?
What does AISO give me?
Is it better than WDM? Why?
Will it affect performance?
What are the optimum settings?
Cheers,
Roy
Cheers,
Roy
Posted Wed 07 Oct 09 @ 5:00 am
You "only really" need to use asio when using timecodes. (CD decks or Turntables)
If you still only use the rmx as your midi controller and soundcard, you can still use the WDM.
Regards;)
Regards;)
Posted Wed 07 Oct 09 @ 5:22 am
You gonna put a picture up of it flightcased then?
Don't worry seen it:)
Posted Wed 07 Oct 09 @ 6:16 am
Posted Wed 07 Oct 09 @ 6:19 am
