It seems as if I can never get my system operating at 100%. I'm damn near but not quite there. Few kinks and issues arise everytime I start up 6.0. Anywho, my main and most annoying issue is no MIXING playback from my headphones. I have everything hooked up correctly, or I hope so. My problem is though when cueing a track and trying to pre-mix I never can get the track that isn't selected by PFL to actually play at the same time. More than likely a simple error on my behalf, but I'd love to know what I am doing wrong. On previous versions this worked fine, seems now I can't get my headphones to play both tracks at the same time for saving myself!
Another question I have is fairly simple, at least to you gurus. Is there anyway I can remove tracks automatically from the search DB that have been either deleted or moved. I hate it when I search a song, it finds 5 versions of it however 3 of the 5 are no longer in the original location. Could one of you fine folks guide me through this simple process? LOL :)
Other than the fact I can't register any of my products due to a previous username that was deleted I suppose I believe those are my only issues thus far, at least hopefully. I'll get back to you all if I have more.
Happy Deejaying...
Acizzle
Happy Deejaying...
Acizzle
Posted Wed 23 Sep 09 @ 10:11 pm
Without knowing what card/console you are using its hard to comment. However - although you may have everything connected correctly, you need to make suure that you have the right setup in the Config.
Go to Sound Setup and make sure the inputs, outputs and soud cards are set up correctly.
On your other point, again in config, go to the Browser tab and select the right drive from the drop down menu in the Database section.
"Check" will remove all the entries for files that are no longer present.
"Clean" will also remove any associated data with these files once they have been removed.
Cheers,
Roy
Cheers,
Roy
Posted Thu 24 Sep 09 @ 4:03 am
Roy,
The soundcard I'm using is the ESI U46DJ unit. The headphones are connected to channel 3/4 set on "Line". Same setting on VDJ with Master being channel 1/2. I'm using a Stealth controller unit if that matters as well.
My database in now clear of any "dead" files. Thanks for the information.
Happy Deejaying,
Acizzle
Happy Deejaying,
Acizzle
Posted Thu 24 Sep 09 @ 10:52 pm
