Do I need midi in and out on my mixer to control software or just midi out MIDI OUT (clock/start/stop). The mixer i'm looking at has midi out only.
Posted Wed 23 Sep 09 @ 11:53 am
You'd only need MIDI in if you wanted VirtualDJ to control your controller (typically used to turn lights on and off).
Posted Wed 23 Sep 09 @ 12:12 pm
If you wish to use it to control VirtualDJ (I.e: Move the video crossfader), then you would need a MIDI compatible mixer with MIDI OUT.
MIDI IN is only used for feedback from VirtualDJ, e.g: To light an LED, and this requires a proper definition and mapping to function. Basic MIDI OUT functions can be mapped using the Simple MIDI Wrapper.
You would also need a MIDI Interface to be able to connect it to your computer, unless it connects via USB as most MIDI controllers such as Hercules do.
Posted Wed 23 Sep 09 @ 12:27 pm
The mixer i'm looking at has "MIDI Clock and MIDI Start/Stop commands"
There is no other info about midi that I can find for this mixer. I want to scroll folders and files, load songs, trigger cue points, trigger effects, trigger samples, trigger beatmatch. Thats all I need a mixer to do.
The mixer is a Ecler NUO 5.
Will this work?
Btw...I do audio only. no video. I use cdj's with tccd and maya44 usb or NI audio 4.
Will this work?
Posted Wed 23 Sep 09 @ 12:40 pm
IIRC the Nuo 4 was Ecler's big MIDI mixer and the Nuo 5 was pretty limited (actually I didn't think it did MIDI at all!) - unless they've changed it in a new version of the product.
Posted Wed 23 Sep 09 @ 1:39 pm
