Hi I have a problem. i am using Virtual dj6 with my RMX however i cant use the jog wheel with the down button pressed to scroll down my tunes any sugestions
Posted Sat 19 Sep 09 @ 10:17 am
If you are using 6.02 you should be able to. The team corrected this issue for 6.02
If you are still using 6.01 then I would go to your download centre and D/L it mate
Posted Sat 19 Sep 09 @ 10:30 am
problem solved thankyou
Posted Sat 19 Sep 09 @ 10:54 am
