hi i'm a mac user and wondered if any one could help me out. i have downloaded a few effects to use in virtual dj. but once i have downloaded them to my mac i do not know what to do next ( how too get them working and running on virtual dj )
please get back too me cheerz sam.
Posted Wed 16 Sep 09 @ 2:00 pm
i haver the same problem mate cant use them once thay have downloaded
Posted Fri 18 Sep 09 @ 5:16 pm
i know its really annoying. im getting bored of the 3 effects i hve now :L
Posted Sat 19 Sep 09 @ 12:22 pm
Firstly i assume you have downloaded Mac compatible effects. You must download the ones with Apple symbol on them, if so.......
When downloaded have you unzipped the file then move the contents to:
for sound effects
/Users/USERNAME/Documents/VirtualDJ/Plugins/SoundEffect
for video effects
/Users/USERNAME/Documents/VirtualDJ/Plugins/VideoEffect
for video transition
/Users/USERNAME/Documents/VirtualDJ/Plugins/VideoTransition
Hope that helps you guts out.
for sound effects
for video effects
Posted Sat 19 Sep 09 @ 12:32 pm
I cant find apple symbol before any of the samples.
Are they only for PC?
If not, step by step on how is much apreciated.
Posted Thu 05 Nov 09 @ 12:00 pm
The samples are standard audio files, so are platform independent. - They should work on both Mac and PC.
Posted Thu 05 Nov 09 @ 1:38 pm
i would like 'echo' effect, is it available in mac?
Posted Thu 05 Nov 09 @ 9:41 pm
I've noticed in my skins folder, there are several 'zip' files. Do I have to 'unzip' them to make them visible, because it seems that most of them are already visible in Vdj6.
Posted Sun 08 Nov 09 @ 6:10 pm
I do not even have an option to unzip the file. it won't even let me open up the samples that i try to download
Posted Tue 06 Sep 11 @ 10:44 am
Please don't bump old topics - This topic is from 2009.
Please also don't post the same message more than once. You have already asked the same question in the following topic, where you can find an answer: http://www.virtualdj.com/forums/153350/MAC_Version_Technical_Support/can_t_lowland_anything_for_my_mac.html
NOTE: Skins in the skins folder must not be unzipped.
[Old topic closed]
[Old topic closed]
Posted Tue 06 Sep 11 @ 4:38 pm
