Hi all,
This has probably been answered already but I didn't find anything.
So I'm using Virtual DJ with an external Hercules DJ Control MP3 and each time I use the faders or the Treble Mid Bass knobbers or the jog wheels it makes a very strange noise that stops as I stop using them...
It's like a "grrrsssh" noise that makes music sound as if it's distorted.
Is there any option to remove this noise? It ruins my sets and remixes =(
Thank you in advance.
Best regards
DJ D-Backs
Best regards
DJ D-Backs
Posted Sat 12 Sep 09 @ 2:12 pm
disengage safemode.
Posted Sat 12 Sep 09 @ 7:16 pm
Hi im havin the same problem also, were about do you disengage safe mode, is it in the config settings? thanks
Posted Thu 17 Sep 09 @ 2:53 pm
VirtualDJ>Config>Performance Tab.
Uncheck safe mode
Posted Thu 17 Sep 09 @ 2:56 pm
ok thanks for your help
Posted Thu 17 Sep 09 @ 3:26 pm
