thanks ill try it at home because my work pc sucks it's got to much security hardware
Posted Tue 19 Apr 05 @ 4:28 pm
And another thing I forgot to mention although can be an issue is this...Some firewalls (Norton, Zone Alarm, etc) sometimes require a full uninstall before it will enable you to open up certain sites/programs. This reason is due to leaving registry keys inside the registry and are removed only once the software is removed.
This is not something I would do first although if disabling the firewall and trying another software doesn't work ONLY THEN! would I attempt to uninstall the firewall.
Regards
DJ White Devil
Regards
DJ White Devil
Posted Tue 19 Apr 05 @ 4:32 pm
ahhh !!! Of course ! Okay try at home and follow the advice of white DVL regarding the firewall !
