i have two dnhs 5500 denon players , and i have it connected to virtual dj , but it does not show me display on the players and i can not scratch because it does not turn the 7'' platter , i just upgraded to a macbook pro ,, help please ,,,,
Posted Tue 08 Sep 09 @ 4:44 pm
You need to be running the latest version to have full functionality of the 5500 ... have you downloaded VV 6.0.2 ? https://virtualdj.com/download/updates.html
Posted Tue 08 Sep 09 @ 5:53 pm
yeah i did , but the new version does not have the midi controllers, or at least i dont know how to set it up ,
Posted Tue 08 Sep 09 @ 6:37 pm
External controllers changed in version 6 ...
Go here and download the VirtualDJ v6 manual ... it will help you out the Config interface is the same .... what you are looking for is the Mappers tab.
https://virtualdj.com/wiki/PDFManuals.html
But, if you followed the instructions outline in the other link I gave you then you should be fine and the controllers should come up correctly.
In v6, if the controllers are correctly setup then they are automatically recognized and activated ... unlike the past where you had to select them and activate them.
Posted Tue 08 Sep 09 @ 10:23 pm
it works , but still wont show me display or turn the jog wheel to scratch
Posted Thu 10 Sep 09 @ 12:30 pm
I am having the same problem, Ive noticed that using a usb (it's a powered one,) also tends to give me more problems.
I also was wondering how to use 2x DN5500s and their corresponding Soundcards, Since they come up as the same unit how can I select the second one?
Posted Sat 17 Oct 09 @ 7:15 pm
well now with the denon 1400 version upgrade works a little better ,,,,,but i still cant use them individually ,,,
Posted Thu 21 Jan 10 @ 2:37 am
y not just use one 5500 and switch between decks via the layer function? works much better..and then u can do everything one handed with one less piece of gear to drag around...
Posted Sun 28 Feb 10 @ 4:11 pm
i really dont see the point on having one turn table , ,, i have called apple , denon , and virtual dj and still the same problem
Posted Tue 25 May 10 @ 11:43 pm
I also have two 5500s and am having the same problem.
Posted Sat 31 Jul 10 @ 2:02 pm
