So with 5.2 I did not have a problem except for the cue slip. It still seems to be happening in 6.0.2 but there is another issue I am having.
I use serato timecode and SL1. When pitch is adjusted on the TTs the song does respond correctly but the pitch control/BPM does not respond in the software it self. BPM will not increase, like it did in 5.2.1.
Also lets say I leave the TT at +4% pitch and load up a next song...the song will play at 0%, VDJ reads the timecode as if it was at 0%, beacuse when i move pitch down, or up song will respond correctly but the 0% pitch is now at 4% (where it was when i loaded the track).
I hope I am clear on that. Does anyone have the same issue? or is this just how VDJ Timecode setup is as of now. I hope not, because that makes it very unsable.
Posted Tue 08 Sep 09 @ 12:36 am
i had and still have this same problem. this is another reason i am still using CUE 5.2 and not VDJ pro 6. it was never addressed in my post so hopefully we can get some answers on it now.
Posted Tue 08 Sep 09 @ 9:03 am
In the config there is a option regardig the pitch reseting to 0 when you load a new song. Turn that off and that will solve one problem. And as so many other threads if you used to have 5.2 and now 6 please register your serial
Posted Tue 08 Sep 09 @ 9:51 am
i don't think thats what hes talking about. if you move the pitch on the cdj the video and song change pitch but the program does not reflect the change on screen.
Posted Tue 08 Sep 09 @ 11:11 am
hi,
same problem here! as i was working with version 5, everything was good but now after the update the pitch fader and the bpm display aren't moving if i move the pitch fader on my turntable :/
don't know how 2 solve it :(
Posted Wed 23 Sep 09 @ 4:01 am
Hi guys i use serato vinyls and a esi mayas44 usb sound card and i dont have this problem.
My bpm does go up and down when i move the pitch on the tuntable but one of the bugs i have found is that say my pitch is on 4% on my turntable then i load a song in virtual dj the song will load at 0% then when i move my pitch slider on my tuntable back to 0% virtual dj is now playing my song at -4%.
I have just decided to disable the pitch within the timecode config as it just makes things alot easier.
Posted Wed 23 Sep 09 @ 7:37 am
My buddy is using 5.2 and he is using a 64bit OS dont know if that is a cause also? I had no issue with that in 5.2 and now in 6.0.2? I will check my settings what I get home and post them here? I have used the MK II / Maya ? RMX all with either TT and CDJ's with NO Issue?
Posted Wed 23 Sep 09 @ 11:12 am
this is a serious issue that the guys above should at least say something on. why hasnt it been addressed.
this is very serious...
Posted Mon 28 Sep 09 @ 11:07 pm
Doesn't seem to affect everyone though; I certainly don't have that problem. If you use relative or absolute instead of smart relative does the problem still exhibit? I'm sure I remember this being discussed before.
Posted Tue 29 Sep 09 @ 7:10 am
