VanStino wrote :
Any other ideas? This is really starting to bug me...
You can use KernRate and RATTv3 to trace the offending driver if you're feeling up to it :)
Posted Wed 09 Sep 09 @ 9:19 am
RATTv3 doesn't work on Vista and KernRate has been replaced by a built-in tool on vista. By the way i've tried both anyways. :P RATTv3 didn't work and the built-in tool didn't indicate any real problems.
Posted Wed 09 Sep 09 @ 10:13 am
Have you tried disabling the "Broadcam Netlink (TM) Gigabit Etherent"
I have device in my Gig laptop and it was occasionally giving me red bars, so I disabled it, and all is fine now :)
Posted Wed 09 Sep 09 @ 11:43 am
Yes, it is disabled. :)
Posted Wed 09 Sep 09 @ 12:09 pm
What about the "Intel(R) WiFi Link 5100 AGN" is that disabled too. Going on your screen shot, it's not.
I would disable that mate.
Posted Wed 09 Sep 09 @ 12:27 pm
Tried that already, it fixed nothing. :)
Posted Wed 09 Sep 09 @ 2:17 pm
How about xperf?
Posted Wed 09 Sep 09 @ 4:00 pm
That program makes my brain implode.
Posted Wed 09 Sep 09 @ 4:12 pm
It's very flexible, but it's quite easy to use for measuring DPCs - and you can overlay DPC graphs against CPU usage and so on too.
This blog may be useful:
http://blogs.msdn.com/peterwie/archive/2008/10/06/measuring-dpc-time.aspx
...and this one...
http://blogs.msdn.com/ntdebugging/archive/2008/04/03/windows-performance-toolkit-xperf.aspx
Good luck :)
...and this one...
Good luck :)
Posted Thu 10 Sep 09 @ 4:36 am
Can this be a problem? :)
Posted Thu 10 Sep 09 @ 11:39 am
Is that at idle?!
Posted Thu 10 Sep 09 @ 11:45 am
I think... at least as long as Xperf doesn't use to much disk activity :)
Funny - i didn't notice this in windows itself...
Posted Thu 10 Sep 09 @ 12:42 pm
Check my log, SBDJ... I don't really know how to interpret it and i haven't got the time atm...
http://www.mediafire.com/download.php?nlo0nikmom3
Posted Fri 11 Sep 09 @ 12:48 am
Info: i've fixed this.
Windows 7 took care of the 1000µs peaks and turned them into 200µs peaks, which is acceptable. The 18 000µs peaks were caused by a function of my graphic card called "Powermizer". Turning that function off (which is not easy, because well... actually you can't) fixed the problem of huge spikes. This might be of use to others experiencing the same problem. (Like the Dell Studio laptops, which could have this problem too).
Posted Fri 25 Sep 09 @ 12:13 pm
