i downloaded trial version of VDJ 6.0, i notice that on deck 1 theres is no sound when i scratch backward it make a sounds only with forward scratch, i haven't encounter this problem with deck 2, is there a known bug regarding this or just my settings.
thanks.
thanks.
Posted Fri 04 Sep 09 @ 8:01 am
you probably have the smart scratch setting on the left deck......if you have the default skin you can see it in the video & scratch mode in the middle of the skin. is a little lock, if is on it will be orange, if is off it will be gray.
Posted Fri 04 Sep 09 @ 8:33 am
thanks for your help, i never knew theres a smart scratch option in VDJ 6.0
now everything works fine.
Posted Sun 06 Sep 09 @ 11:11 am
No prob, hope to see you soon as Pro
Posted Sun 06 Sep 09 @ 8:09 pm
