Installing VDJ 6 has caused a few problems. The sync button blinks on and off. How can I change the speed of the Wheel fast forward / reverse? I want it to scratch while paused and move the song faster or slower in play mode. Problem is - it moves the song too fast with each spinn. I want to move forward in smaller increments.
Posted Sun 30 Aug 09 @ 5:57 pm
To turn off the blinking, go to CONFIG -> Mappers, choose the DMC-2 in the list and then change the mapping for SYNC to:
For pitch bending when playing, press the WHEELMODE button to select jogwheel mode (LED of the button off.)
To adjust the jogwheel sensitivity, go to CONFIG -> Options and move the sliders (Make sure you are running the latest v6.0.2 version.)
nothing & sync
Posted Mon 31 Aug 09 @ 12:16 pm
