Forum: Old versions
Topic: VirtualDJ 6 & Denon DN-HS5500 - Page: 1
I noticed there are a few slider controls in the options menu for the platter. Does anyone know the best settings for the Denon DN-HS5500's.
Posted Sat 29 Aug 09 @ 8:37 pm
Posted Sat 29 Aug 09 @ 10:50 pm
cstollPRO InfinityMember since 2004
Scratch - 130-140%, CUE 100%, Bend 80-90%
Posted Sun 30 Aug 09 @ 2:26 am
Thanks cstoll.
Posted Sun 30 Aug 09 @ 7:55 am
I've tried the settings Cstoll recomended above, but I still get alot of cue slippage when scratching. I'm using 2 5500's. Both of them have the jog trans at 3ms. I'm using Windows XP. What else can I try?
Posted Thu 03 Sep 09 @ 8:43 pm
Then continue to adjust the Scratch Sensitivity ... I just gave you a starting point ...
Posted Thu 03 Sep 09 @ 8:48 pm
Should I go higher in percentage?
Posted Fri 04 Sep 09 @ 5:33 am
tight to loose = higher to lower = thick to fluid
higher means you have to work harder at moving the platter to move the track
lower means lesser movement of the platter to move the track
I hope that helps ... depends on the direction of 'slippage' ... if when bringing it back to the CUE point it doesn't quite get there all the time .. then I would say maybe move it lower - 110-120ish ... if it is goint past the cue point then maybe up the value - 140-150
Posted Fri 04 Sep 09 @ 7:56 am
Hi Cstoll,
When scratching and bringing the platter back, it goes past the point. I followed your instructions to raise the percentage up. I ended up at max on the slider in the options menu. The platter reacts the same. It feels to me that the slider isn't doing anything to change the feel of the platter.
Posted Sat 05 Sep 09 @ 8:02 am
Are you changing the slider and not closing the config before testing ?
Posted Sat 05 Sep 09 @ 10:18 am
I'm closing the config menu, them I reload the track and the feel on the platter is the same.
Posted Sat 05 Sep 09 @ 11:34 am
bump.
Posted Sun 06 Sep 09 @ 12:03 pm
Still having issues with the platter in Virtual 6.0.2
My operating system is XP and I have My jog trans set to 3ms.
When I have both jogs in scratch mode so they both spin, while playing 2 songs, if I try to scratch one of them I get heavy drifting.
Posted Mon 02 Nov 09 @ 7:01 pm
Dude do urself a favor an get a sl3 box and problem is solve
Posted Tue 03 Nov 09 @ 12:27 am
Dude, I'm using a RME Fireface 400 which is 10 times better.
Posted Tue 03 Nov 09 @ 8:51 am
Rane SL3 is not currently compatible with VirtualDJ and other DJ software - It has no ASIO (PC) or Core Audio (Mac) drivers available, so will only work with Serato.
Rane SL1 is supported by VirtualDJ on Windows PC only (No Core Audio drivers for Mac.)
A good 4-in/4-out card for timecode use with VirtualDJ is the Native Instruments Audio 4 DJ (Or 8 DJ)
Posted Tue 03 Nov 09 @ 12:32 pm
We're going off topic here. I have a very good sound card (RME Fireface 400). I'm not running the Denon 5500's in timecode. I'm using them in usb mode with Virtual. The problem is I've tried all the settings Cstoll recommended but I still get heavy drifting when scratching while both players are spinning. It's not as bad when scratching while the other player is not spinning.
Posted Tue 03 Nov 09 @ 5:06 pm
Is anybody else using the Denon 5500's in midi mode with no problems?
If so, what are your settings?
Posted Tue 03 Nov 09 @ 5:55 pm
I guess not.
Posted Thu 05 Nov 09 @ 12:26 pm
John,
Are both decks on Layer 1 ? The right deck should be on Layer 2 .
Posted Thu 05 Nov 09 @ 1:12 pm
41%
