Why there's not a fixed post with tips and tricks commonly used at VirtualDJ forum?
Such as:
- post youtube videos
- post images
- post links
To the ones who got the keys: could you post simple "how to do it" tutorials to us? Text only, please...
Such as:
- post images
- post links
Posted Fri 28 Aug 09 @ 1:54 pm
Speedy, when you post a message here, in the window you type, look near the bottom of that page. You will see a + sign with the words SYNTAX HELP everything you need to know is there.... Just click on the + sign and you should be good to go...
Posted Fri 28 Aug 09 @ 1:56 pm
That is why there is a wiki and a place to post that kind of stuff .... oh, and I think Tayla has posted some of that in there .... hmmm
Thank you very much, I didnt observed that sintax stuff.
There are some videos at Tayla's home page, but I can not use youtube now :( [corporative network].
Posted Fri 28 Aug 09 @ 1:59 pm
Oh, just one more question about it.
Could you disponibilize the SINTAX HELP at Home page change profile description box?
Posted Fri 28 Aug 09 @ 2:43 pm
thanks Chris, always best guys to check the wiki out, it's so under used by all of the community. don't forget anyone can add to it either in text, video or jpg and it's so simple to add your own work to help the rest of the community, just add as if you were making a post.
if anyone needs a video made to help with an explanation let me know.
Posted Fri 28 Aug 09 @ 5:00 pm
speedy which files can you get into and i'll put files into that if you want.
Posted Fri 28 Aug 09 @ 5:10 pm
Tayla
I felt the needs of sintax help in home page profiles dialog box when was trying to put a link there. But with the Tearemup tip, I did it.
So I think this could be easier if the "sintax help" could be found at that dialog box. Its just a suggestion to the webmasters.
Thank you.
Thank you.
Posted Mon 31 Aug 09 @ 12:48 pm
