Hi i'm new in this forum so excuse me if my questiond have been answered before although i searched a lot. Well i i'm a proffessional DJ in Greece using Hercules for 2 months now.
I have the version 1.09 (was included with Hercules) .
1) How can i prelisten both tracks simultaneously in Hercules console?
2) How can i connect hercules in external mixer so i can have 2 channels in mixer ?
3) Habe you notice gain problem in some tracks (balance problem in speakers )?
Posted Thu 14 Apr 05 @ 12:54 pm
1. Use headphone mix (either make such a shortcut, or use a skin that has such a slider)
2. Only possible with the full version of VDJ
3. Turn off limiter, and turn on autogain
Hope that helps :)
Posted Thu 14 Apr 05 @ 12:57 pm
Thank you very much for you interesting, can you name a skin that has slider ?
Where is the limiter ?
Posted Thu 14 Apr 05 @ 1:10 pm
The limiter is in the options menu.
Posted Thu 14 Apr 05 @ 6:16 pm
Found the limiter ,Found skin with slider but when i tried to load it says "invalid skin 182line error" ,any tips?
Posted Thu 14 Apr 05 @ 6:43 pm
sounds like the skin is 2.x compatible only. read the description of each skin.
Posted Fri 15 Apr 05 @ 1:48 pm
