Hi I've testing VirtualDJ ver 6.0 and 6.01 trial. Which support my mixer device (Numark TotalControl). Entire of the knot and the led and unled button is working fine with VirtualDJ ver 5.2 and below. As I test the new version of VirtualDJ, which some addition function is really useful, I mean better then previous ver.
The thing is the most important function for change folder is not working (LED_LOAD Button). When try to look at the mapping for my Numark TotalControl (New function which you can change the knot and button function) is not working. If you go Config the mapping tab, the setting show LED_LOAD = folder_browse but the function does not work. Even I try to reload the original setting, Even I update my mixer firmware.
Is the program still have a bug for Mixer controller?
Posted Fri 21 Aug 09 @ 4:31 am
