Ok guys i just wanted to know if i can use a uca 202 as an additional sound card for my laptop, it only has one output jack so i need another output for my headphones.
Posted Fri 21 Aug 09 @ 12:24 am
Yes the Behringer U-CONTROL UCA202 will work fine in VDJ.
Are you just using the laptop and no controller unit?
DJ RuDe
BTW: This topic has been discussed here, check it out...
https://virtualdj.com/forums/96550/Hardware_Technical_Support/behringer_uca202_questions.html
and...
https://virtualdj.com/forums/97659/Hardware_Technical_Support/Behringer_UCA202_question.html
and here is a quick video...
DJ RuDe
and...
If you need more outputs try another soundcard such as a Maya 44USB, this is a popular soundcard around here...
Here is a discussion here on the VDJ forums about the Maya vs the Numark DJ IO...
https://virtualdj.com/forums/95203/General_Discussion/ESI_Maya_44_usb_-_OR_-_Numark_DJ_IO__which_is_better_.html
Posted Fri 21 Aug 09 @ 1:00 am
