after I purchase VDJ pro then what sound card do I need to get?
I did look at cdj 400 and also hercules rmx, but if I want to run only on my laptop - which sound card do you recommend
thanks!
dj4nse
thanks!
dj4nse
Posted Thu 20 Aug 09 @ 5:04 am
Hey dj4nse,
both controllers own a onboard soundcard.
So you need nothing more then VDJ PRO from here:
Haui
Haui
Posted Thu 20 Aug 09 @ 5:19 am
both cdj and rmx should run through a USB port. Your laptop should have integrated sound card, into which you plug in your speakers. If you want preview headphones, then buy a USB soundcard, or check if rmx or cdj have a built-in soundcard for previews.
