Hi. Can anyone recommend a sound card for using with numark cue. I have a DJ I/O but have had unsolvable problems with it and would like to try another card. I need to monitor the track not playing out the master channel in my headphones whilst mixing as you would with vinyl djing!
Thanks
Matt
Thanks
Matt
Posted Wed 19 Aug 09 @ 2:46 pm
What's the unsolvable problem, I use the DJio and have no issues.
Posted Wed 19 Aug 09 @ 2:57 pm
It produces a distortion. Ive tried all the advice given here, including the latency checker. The distortion appears randomly. I did a mix the other day, no distortion at all. Listened back to it today and the distortion was back. Appears for about 15 secs then goes for a random amount of time then comes back. Its driving me mad. Ive even had the laptop re formated, back to 'new' with just O/S put back on. I run Vista 32 with 3gb ram. 160gb HD and AMD Turion dual core!
Posted Wed 19 Aug 09 @ 3:04 pm
Seems to be the same thing:
https://virtualdj.com/forums/114351/Hardware_Technical_Support/Distortion_with_Numark_DJ_I_O.html
Posted Wed 19 Aug 09 @ 3:07 pm
I was thinking the same thing...Crack version distortion. If you are using a cracked version no sound card will correct the problem. It's a "feature" of cracked versions to enhance the experience :)
If you are using a registered legal version, you should put the registration # in your profile, and the software and see if the problem goes away.
Posted Wed 19 Aug 09 @ 3:12 pm
It is! Sorry. I only replied 'cos they asked!
MAYA 44 USB is a godsend.
works perfect
works perfect
Posted Thu 20 Aug 09 @ 12:48 am
Thanks. Will have a look!
M
M
Posted Thu 20 Aug 09 @ 3:25 am
Matt are you using your DJio as an ASIO device, or a 4.1 card? I have had much better results using ASIO.
Posted Thu 20 Aug 09 @ 9:14 am
As an ASIO device.
Posted Thu 20 Aug 09 @ 11:14 am
