I am getting the recovery window with the yellow smiley face.
I have a Dell Inspiron 6400 with a 2.0 pros and 2gigs ram. I am using a maya 44 usb sound card and the newmark dmc2 controller
I've had this pc for a while now and never had any problems with virtual dj but all of a sudden last week the program started crashing on me during a few gigs.
I was running the new version of vdj (6.0.1) and it crashed 2 different times during a gig.
I was playing for about an hour or so and all of a sudden the screen came up that said something like "fatal error shut down or recover"
Not sure what to do...I reinstalled and older version (5.2) and i happend 2 more times.
I ran 4 different virus scans on my pc and it came up clean.
Here is my last crash report...
Crash ID=004726a1 (date=804051906, version=5.0 rev.6, build=506, thread=Main, dump=8b421451, excode=c0000005 (0,14))
Crash ID=100069b0 (date=805281756, version=5.0.7, build=507, thread=Main, dump=8b401c8b, excode=c0000005 (0,1c))
Crash ID=00481930 (date=809161845, version=5.2 Pro, build=520, thread=Main, dump=8338000f, excode=c0000005 (0,8d5))
Crash ID=00428aa5 (date=810231609, version=5.2 Pro, build=520, thread=Scan, dump=8934823b, excode=c0000005 (1,4))
Crash ID=7c9c6f54 (date=904031112, version=5.2 Pro, build=520, thread=Main, dump=a30e00c0, excode=c0000005 (1,4fc0000e))
Crash ID=00481930 (date=904271024, version=5.2 Pro, build=520, thread=Main, dump=8338000f, excode=c0000005 (0,d7b80))
Crash ID=7c9666f0 (date=908051330, version=6.0.1 Pro, build=601, thread=OutputASIO, dump=c9c20400, excode=c0000008)
Crash ID=7c9666f0 (date=908052118, version=6.0.1 Pro, build=601, thread=Scan, dump=c9c20400, excode=c0000008)
Crash ID=7c9c6ecc (date=908102059, version=6.0.1 Pro, build=601, thread=Main, dump=f0d9c31a, excode=c000001e)
Crash ID=00481684 (date=908111132, version=5.2 Pro, build=520, thread=Main, dump=8b460883, excode=c0000005 (0,3011f88))
any help with this matter would be great.
I'm not sure what to do and i have a gig tonight and i really don't want to reformat my pc and start over.
thanks
thanks
Posted Tue 18 Aug 09 @ 10:16 am
thanks
thanks
1st I have the same problem past years, if you try to run with video out or the format of your videos was vob your computer saturated the cpu process, chance the format of last download videos.
2nd check your sonique version for video image, one of this version has a bug that cause the happy face, check the video effect too, some of this video effect has this bug.
3th check your keyboard if you has a key fail contact, saturated with a command vitual process.
vj mr mix
Posted Tue 18 Aug 09 @ 12:14 pm
Thank you for trying to help me out but I wasn't playing videos I was playing mp3's.
I wasn't using any effects or samples. I was just playing music.
I play videos on my mac with VDJ
Posted Tue 18 Aug 09 @ 12:27 pm
