dregsta-ink wrote :
Ur stuck in a rutt arnt you buddy
Is that your answer to my question?
Posted Mon 17 Aug 09 @ 1:27 am
For SB:
I'll run some tests though as I would have never run into your issue personally - I don't use automix and I rarely use the keyboard. Do you just manually drag and drop into the two players perhaps temporarily storing in the playlist and getting your drops from there?
Automix could be having some impact on the resets though - depending on what mode of automix you are using, VDJ may attempt to choose the next tracks configuration itself hence no need to reset as such. How about running without using automix - does everything work fine for you then? Will test everything to be sure and get back on this.
Yes the parameters reset with the manual use of the two players.
[/quote]
[/quote]
Posted Mon 17 Aug 09 @ 1:37 am
DanceHost wrote :
Patient learning is what we are into here. Seems 78's were about done around '48 when the 45s and LPs came in.
All I need are a few basic controls. How long should a learning curve take for this?
What is the problem with file date showing? What other dos and dont's should I be aware of for my needs? One of the members said what I was asking for was 70's standard procedure.
Can you personally keyboard control Key, Pitch and Gain in Automix and have the next file to automatically reset?
Thanks
steelwill wrote :
DanceHost,sometimes i think you should try again from the top. check your keyboard & mouse to make sure that's not the problem.
make sure your filedate is'nt showing, defrag your hardrive and so on. i think you need to have a little patience with the program
and learn 1 thing at a time and not all at once. i'm sure there is some function this program can provide to enhance your shows.
i been in the biz over 30 years. (since 78 rpm records.) i'm still head and shoulders over the compitition. since i do video now
my calender is full thanks to vdj.
-will-
-will-
Thanks
Posted Mon 17 Aug 09 @ 1:46 am
DanceHost wrote :
If that is the case, that surely takes the fun out of it. Seems almost like a case for using Windows Media Player.
Automix takes the fun out of it? I can't understand that sentiment I'm afraid - I'd have thought it was the other way round in the case of VDJ.
If you want a glorified jukebox system, there are better solutions at this time than VDJ as you've found. Most desktop players will have features that are just not needed in VDJ for 99.9% of users.
If you want a capable, flexible, controllable, customisable, professional DJ/VJ solution then thats what VDJ is mainly targeted at IMHO.
Posted Mon 17 Aug 09 @ 6:43 am
You said Automix might not work. All i meant was if Automix wont work that would take my fun out of it. I don't understand our communication problem
SB why make excuses that VDJ is not this or not that and just bite the bullet and fix the problem at hand?
DanceHost wrote :
.If that is the case, that surely takes the fun out of it. Seems almost like a case for using Windows Media Player.
If its all of that its a jukebox system too. You can't cover problems with platitudes.
Yesterday you were going to make Automix keyboard tests. What happened to that? I really would like for you to see what you get working with Pitch and Key in Automix.
Posted Mon 17 Aug 09 @ 9:45 am
Does anyone else besides me smell a troll in here!
Posted Mon 17 Aug 09 @ 10:39 am
Firstly - I can't fix the issues since I don't work for Atomix. Secondly, I'm trying to explain to you that this is how it works. If that's not to your liking then maybe you should have done more testing before buying. It provides basic playlist functionality combined with some limited beatmixing. It's not intended to be used in the manner you are trying to use it. It's really designed for you to list a load of tracks and walk away - not attempt to meddle with what it's doing. I'm not attemting to cover up problems - I'm attempting to explain how the software works.
I haven't had the chance yet - I've got a day job, my DJ work, a family coupled with a few more important tasks that need to get done. It was an offer of assistance however you don't seem to want to answer my questions in any real detail so that I can even try and help you.
So in the absence of any information I'll give you the best advice I can at this stage: Stop being lazy, drop the automix and earn your fee ;)
If at some point you decided to be a bit more forthcoming with information, a bit more helpful and perhaps a little less abrasive I may reattempt to assist you.
Posted Mon 17 Aug 09 @ 10:48 am
+1
Posted Mon 17 Aug 09 @ 12:31 pm
DanceHost wrote :
With your settings, can you keyboard control Key, Pitch and Gain in Automix and have the next file to set properly?
How about listing the settings I need as you see them?
I never, ever, control the gain via the software. I use an outboard mixer, or EQ for that. Software is not meant for that type of application. Pitch is controlled via a controller, or time codes. Once again, it is not the software's job. Why would any DJ want to control key? The artist chose to perform a song in a certain key, and it is not up to us to second guess the artist, only to press play on their songs.
If you are looking for VDJ to use it as a production tool, you choose the wrong platform. If your looking to throw 5 hours of music onto a side list, and expect perfect transitions, you choose the wrong platform. Our job as DJs is to press play. Either on a turntable, CD player, or PC screen. Not to set 'em, up and walk away. Auto play is a useful tool. I use it often, during dinner music, or bathroom break. It does not replace me behind the controls for the whole night though.
I was simply offering options. Not a format for debate. If my advice is not appreciated, please do not feel the need to read it. Enjoy the rest of your time on our forum.
Posted Mon 17 Aug 09 @ 2:01 pm
SB:
You can't fix the issue. What issue? You haven't tested yet to see if there is an isssue. How what works? I checked before buying and was told all my concerns would be easy. The skins show the controls. Mapping instructions are rampant. Are you satisfied without testing that you can't massage within Automix?
I appreciate your help and will wait on you. Yesterday you were going to make the tests and you asked me if a single load worked with key control and I answered yes. Then you start this dialogue today which doesn't seem to be your normal style.
No one has answered my questions so far but have called me names and made disclaimers. If you were to read back through this thread, VDJ has been discounted as a KJ tool, a Jukebox and even a DJ Tool with Automix basically said to be unnecessary, and you are the only one who has offered to help with the questions.
SB, what specifically have you asked me that I haven't answered?
You want me to stop being lazy. It is not lazy to seek the key on each song for a vocal participant or pitch each song for a dance participant. How do you handle requested key changes for singers and requested dance tempos for dancers? I asked you if you DJ by alternating with single alternating loads to each player. Still would like your answer on this.
Abrasive? I am only responding to what I am given.
SB, let me summarize. Let's forget Gain. I agree with another member, there are better ways to control gain than with a keyboard, however keyboard is needed here for precision control of Pitch and Key. (I am using only a computer and a basic mixer.)
All I need is for you to test the + and - of this using four keys on the keyboard and tell me if this mapping is viable with Automix. Again when you can.
Thanks
Posted Mon 17 Aug 09 @ 4:29 pm
TEU, interesting what you do but how about giving me the settings for what I need?
I want to join you on Gain, let's forget that. I can handle that with my mixer. I do need Pitch and Key keyboard control.
Not the softwares job? Then why are the controls in the software? What are mapping configurations for?
A DJ probably wont need to change the key of a song but a KJ may need to do that 12 times a night. We audition all our participants and half of their tracks are in the wrong key for their voices so they have to be changed. Now before you say that is not a function of VDJ, I ask again, why is this provision on the skin and in this software?
TEU, I have the simple question of what settings do I need to keyboard control Key and Pitch within Automix? This is the advice I need from you. I have this question but have not got an answer to it but only disclaimers, name calling and second guessing.
Thanks
Posted Mon 17 Aug 09 @ 5:02 pm
I'd asked for more specific information as to what you are doing with all the different controls, what you are seeing, along with details as to whether you always use automix and what mode.
I'm a bar/club DJ, so yes, I work by single loads to each player coupled with the sampler - but not necessarily alternating. I don't have to deal with requests for different keys and tempo. If I did then I would work as I do now, setting the key and tempo for each track as appropriate. By using automix for convenience you are sacrificing the flexibility of control over individual tracks.
OK, so you are trying to do this using whilst automix is active. This isn't what it was designed for I'm afraid - you'll have to mix manually.
They are there for people who are wanting to control their tracks fully. By using automix you sacrifice some functionality.
As above. I doubt a KJ would be using automix anyway?
In case you didn't get the point of my post: You need to not use automix. By enabling automix you are effectively saying: "Dear VDJ, I'm either currently unable, not needed to DJ or just too bone idle. Please do it all for me whilst I go to the bar and chat up some women" ;)
Posted Mon 17 Aug 09 @ 6:54 pm
Don't remember seeing those requests. Thought you would take my simple proposistion and test it through Automix. I'm not sure you or any member has done that but rather basically choose to disclaim.
Sounds like another disclaimer. Why not have this put in Automix?
OK, so you are trying to do this using whilst automix is active. Yes, for the umteenth time. What part of the question did you not understand? What tests were you going to make for me a couple of days ago? This isn't what it was designed for I'm afraid - you'll have to mix manually. Why not?
Have Automix improved then don't relegate it to secondary citizen status.
As above. I doubt a KJ would be using automix anyway? I am trying to and it could be a powerful KJ functionality. Not to be redundant but the free Winamp has no trouble with this in their automatic mode.
One last question, have you or will try my proposistion?
Really sad to be so limiting.
Posted Mon 17 Aug 09 @ 8:12 pm
Hello....
Posted Wed 19 Aug 09 @ 2:21 am
You've had the answer I'm afraid: Automix isn't suitable for what you want to do.
You have several choices at this point...
1. Ditch automix and DJ yourself
2. Adapt what you are doing to work with automix
3. Use a different software more suited to jukebox style functionality
There really isn't any more to say than that. Automix may be upgraded more in future versions, then again it may not. Future features are never announced before release.
Posted Wed 19 Aug 09 @ 6:14 am
Okay, I am missing something here. The features you want work perfectly you say when you Dj manually using BOTH players. Why don't you use the 2 players as designed and your problem is solved. You say you have been Djing for decades, before the advent of software did you use only 1 cd play or 1 turntable or 1 grammaphone and have all you records and cds changed for you automatically?
You are trying to manipulate parameters of individual songs in AUTOMIX mode. The AUTOMIX mode (just by it's name should give you a clue) is NOT designed for you to make adjustments to individual songs....if you want to manipulate the individual songs that is called Djing and you do that with the 2 Dj players. The AUTOMIX mode is designed to be "AUTOMATIC" which by definition means no interaction with it once you start it.
Several people have tried to explain this to you and you have shined them off by saying they are making excuses. It is not an excuse to say something is NOT designed to use it in the way you are trying to use it. YOU are simply trying to use a feature improperly, period, point blank, that's the facts Jack.
I am quite franklly surprised you have continued to get responses from peopl trying to explain this to you....it just goes to prove the resolve of the great users of the program and this forum as to what extent they are willing to try and help. You can be assured if you were on a hammer forum and kept compaining your screwdriver didn't drive in nails you wouldn't get much love and essentially that is what is happening, you purchased a tool designed for a totally different job than you are trying to perform.
Please don't take this as rude, but you just don't seem to get it so here it is in plain, simple, between the eye English. It can't be fixed because it is not broken......You CAN NOT do what you are trying to do because YOU are using the feature improperly...the manaul features you are trying to use in an automatic mode DO NOT WORK, THEY ARE NOT ACTIVE with the automix, the program is NOT coded for that use.
My suggestion is for you to continue to use winamp if it works for what you want, or check out another program specifically designed for Karaoke like the Swift Elite Hoster.
Posted Wed 19 Aug 09 @ 12:00 pm
Thanks
Posted Wed 19 Aug 09 @ 3:08 pm
"Please don't take this as rude, but you just don't seem to get it so here it is in plain, simple, between the eye English. It can't be fixed because it is not broken......You CAN NOT do what you are trying to do because YOU are using the feature improperly...the manaul features you are trying to use in an automatic mode DO NOT WORK, THEY ARE NOT ACTIVE with the automix, the program is NOT coded for that use." - dj-e-lectric
Hi dj-e-lectric,
Got on my more powerful Desktop last night and the manual features do work in Automix except for the the reset. I have a ticket in about the reset and bet they help me with that.
Try my proposistion for yourself. We can all learn something here. Automix is a marvelous feature and deserves a better press. It allows you to get the forest in front of you and can be manipulated for each song. Far from being lazy it provides a more efficient tool than loading just one track at a time and allows you to think ahead.
I invite all theAutomix detractors to try my proposistion and give Automix a chance and maybe be a little kinder to the next member who asks about a feature that apparently has garnered so many predjudices.
Hi dj-e-lectric,
Posted Wed 19 Aug 09 @ 3:32 pm
