Hey guys i got a question that i need help with.
I just set up my maya 44 usb soundcard with my turntables and mixer and i get 100% signal from my timecoded vinyls. When i play it i can only hear sound out of my headphones when i cue it up on my mixer and i get no sound coming from my speakers. My speakers are plugged in through my mixer under "Master" through rca cables. How can i get sound out of my speakers?
Posted Fri 14 Aug 09 @ 12:01 pm
Did you check the soundcard settings under the "Config" menu of VDJ to make sure your soundcard and the correct drivers are in the dropdown menu?
DJ RuDe
DJ RuDe
Posted Fri 14 Aug 09 @ 2:33 pm
I got sound now, thanks. However i have 1 more issue:
I cannot control virtual dj through my turntables. They bug out(say they are playing ver very fast when my turntable isnt playing) even though my timecode is at 100%
Posted Fri 14 Aug 09 @ 4:52 pm
