i broadcasted through vdj using shoutcast, how am i able to listen back to my mix.........it has to be recorded somewhere, it says recording .....plz help.......thanks
Posted Fri 14 Aug 09 @ 4:55 am
i don't think you can broadcast and record at the same time it has to be one or the other
Posted Fri 14 Aug 09 @ 7:21 am
This is correct. Call it a glitch that it shows recording, while broadcasting. If you wish to record your stream try using Winamp, with the Streamripper pluggin. Works like a champ!
Posted Fri 14 Aug 09 @ 7:58 am
I usually use "castripper" for recording shoutcast. It´s a very simply program. Only type the IP of the server you want to record and it´s ready. But if you want the best quality for your recording better use a soft that records directly from your soundcard, like Cool Edit for example.
Posted Wed 19 Aug 09 @ 8:50 am
Audacity is my fav, I run a line directly into another pc and record that way while playing on VDJ Radio
Posted Wed 19 Aug 09 @ 11:56 am
