Hello Mart ,
You can put your question, In English about the général forum
http://fr.virtualdj.com/forums/30/General_Discussion.html
Posted Wed 28 Oct 09 @ 12:13 pm
Salut j'ai aussi la meme consoler la i-mix mais pareil je n'arrive pas et je suiis une quiche en mappage et XML tu pense qu'il y a moyen que tu m'envoie le fichier par mail??
Salut et bonne continuation
Posted Tue 01 Dec 09 @ 2:38 pm
Hi Mart,
Just styarted to configure VDJ to work with my brand new Imix reload.
You can copy the following into a .xml file as start.
As a lot, I'm struggling to congigure the jog wheels but the script covers all the main features.
If you're using a demo version, it's not likely you have the possibility to use an external midi controller.
<?xml version="1.0" encoding="windows-1252"?>
<midi version="5" date="12/12/2009">
<note note="101" action="browser_updown" value="-1" />
<note note="100" action="browser_updown" value="+1" />
<note note="40" action="browser_open" chan="1" />
<note note="46" action="browser_open" chan="2" />
<note note="17" action="play_pause" chan="1" />
<note note="47" action="play_pause" chan="2" />
<note note="5" action="beatlock" chan="1" />
<note note="35" action="beatlock" chan="2" />
<note note="11" action="cue_stop" chan="1" />
<note note="41" action="cue_stop" chan="2" />
<note note="8" action="set_cue" chan="1" value="1" />
<note note="32" action="set_cue" chan="2" value="1" />
<note note="14" action="set_cue" chan="1" value="2" />
<note note="38" action="set_cue" chan="2" value="2" />
<note note="20" action="set_cue" chan="1" value="3" />
<note note="44" action="set_cue" chan="2" value="3" />
<note note="1" action="loop" chan="1" />
<note note="25" action="loop" chan="2" />
<note note="10" action="effect_select" chan="1" value="+1" />
<note note="22" action="effect_select" chan="2" value="+1" />
<note note="4" action="effect_select" chan="1" value="-1" />
<note note="16" action="effect_select" chan="2" value="-1" />
<ctrl ctrl="68" mode="slider" action="effect_slider_1" chan="1" />
<ctrl ctrl="70" mode="slider" action="effect_slider_1" chan="2" scale="0" />
<ctrl ctrl="64" mode="slider" action="effect_slider_2" chan="1" />
<ctrl ctrl="76" mode="slider" action="effect_slider_2" chan="2" scale="0" />
<ctrl ctrl="65" mode="slider" action="crossfader" scale="0" />
<note note="18" action="kill_bass" chan="1" />
<note note="36" action="kill_bass" chan="2" />
<note note="24" action="kill_medium" chan="1" />
<note note="30" action="kill_medium" chan="2" />
<note note="28" action="kill_high" chan="1" />
<note note="34" action="kill_high" chan="2" />
<ctrl ctrl="77" mode="slider" action="bass" chan="1" scale="0" />
<ctrl ctrl="82" mode="slider" action="bass" chan="2" scale="0" />
<ctrl ctrl="79" mode="slider" action="medium" chan="1" scale="0" />
<ctrl ctrl="72" mode="slider" action="medium" chan="2" scale="0" />
<ctrl ctrl="78" mode="slider" action="high" chan="1" scale="0" />
<ctrl ctrl="80" mode="slider" action="high" chan="2" scale="0" />
<ctrl ctrl="71" mode="slider" action="gain" chan="1" scale="0" />
<ctrl ctrl="81" mode="slider" action="gain" chan="2" scale="0" />
<ctrl ctrl="67" mode="slider" action="level" chan="1" scale="0" />
<ctrl ctrl="66" mode="slider" action="level" chan="2" scale="0" />
<ctrl ctrl="69" mode="slider" action="pitch" chan="1" invert="true" scale="0" />
<ctrl ctrl="75" mode="slider" action="pitch" chan="2" invert="true" scale="0" />
<note note="3" action="key_lock" chan="1" />
<note note="45" action="key_lock" chan="2" />
<ctrl ctrl="73" mode="slider" action="headphone_volume" scale="0" />
<ctrl ctrl="74" mode="slider" action="headphone_crossfader" scale="0" />
<note note="114" action="jogwheel" chan="1" />
</midi>
</midi>
Posted Sat 12 Dec 09 @ 11:13 am
Salut à tous,
j'ai bien lu attentivement vos messages en ayant fait ce que vous dites mais j'ai un soucis assez différent et question mappage et programmation ... enfin bref, j'ai réussi à assigner quelques touches de ma DJ-Tech i Mix sur VDJ 6 (Play/Cue/Reverse/In/Out/Reloop/Set/Auto Mix/et certains crossfader) mais le soucis c'est qu'elles ne marchent que sur la platine en cours (du logiciel) et j'ai beau appuyer sur le bouton "Play", par exemple, du coté droit ou gauche de mon controller, seul le "Play" de la piste en avant sur le logiciel se mettra en route. J'ai également le même soucis que certaines personnes, celui des jogwheel qui ne fonctionnent pas ! Bref un vrai bordel =S Si quelqu'un pouvait m'aider, je suis preneur de toutes propositions !!!
Posted Sat 16 Jan 10 @ 5:10 pm
En fait, j'ai réussi à assigner les touches selon la Deck mais je n'arrive toujours pas avec les jogwheel et certaines touches du haut de ma DJ Tech i Mix comme "Monitor" ou les touches pour changer de pistes.
Si quelqu'un pouvait m'aider, je n'ai pas envie de mixer avec des touches qui ne marchent pas !
Posted Sun 17 Jan 10 @ 2:19 am
Bonjour à vous tous, je possède également une table de mixage Dj-Tech I-Mix. Mon problème le mappage. Je suis débutant mais en lisant vos posts j'arrive à déchiffrer. Maintenant j'aurai aimer savoir si il est possible quu'ne personne puisse m'envoyer le mappage à cette adresse: nicomuted@live.fr
Je vous remercie d'avance en ésperant que vous pourrez m'aider car je commence a baisser les bras. Bonne journée à vous tous
Posted Thu 18 Mar 10 @ 5:28 pm
Nico j'espère que tu ne vas pas posté dans tout les topics
je t'ai répondu ici --> http://fr.virtualdj.com/forums/113038/French_Forum/map_i-mix_reload_pour_vdj_6_.html
Posted Thu 18 Mar 10 @ 5:39 pm
voila une copie de mon fichier xml:
<?xml version="1.0" encoding="UTF-8"?>
<device name="SIMPLE_MIDI" author="ALEXIS" type="MIDI" decks="2" drivername="Périphérique audio USB" sysexid="F0 7E 00 06 02 48 50 01 01 00 05 00 03 00 04 00 F7 ">
<button note="83" name="browser_scroll +1 DECK1" deck="1" />
<button note="81" name="browser_scroll +1 DECK2" deck="2" />
<button note="10" name="browser_enter DECK1" deck="1" />
<button note="45" name="browser_enter DECK2" deck="2" />
<button note="82" name="browser_scroll -1 DECK1" deck="1" />
<button note="80" name="browser_scroll -1 DECK2" deck="2" />
<button note="0-20" name="play DECK1" />
<button note="55" name="play DECK2" deck="2" />
<button note="0-13" name="cue_play DECK1" />
<button note="48" name="cue_play DECK2" deck="2" />
<button note="14" name="pitch_bend +5% DECK1" deck="1" />
<button note="22" name="pitch_bend -5% DECK1" deck="1" />
<button note="49" name="pitch_bend +5% DECK2" deck="2" />
<button note="29" name="pitch_bend -5% DECK2" deck="2" />
<button note="5" name="sync DECK1" deck="1" />
<button note="12" name="sync DECK2" deck="2" />
<button note="1" name="loop_in DECK1" deck="1" />
<button note="8" name="loop_out DECK1" deck="1" />
<button note="36" name="loop_in DECK2" deck="2" />
<button note="43" name="loop_out DECK2" deck="2" />
<button note="15" name="reloop DECK1" deck="1" />
<button note="50" name="reloop DECK2" deck="2" />
<button note="27" name="stop DECK1" deck="1" />
<button note="34" name="stop DECK2" deck="2" />
<slider cc="68" name="pitch DECK1" deck="1" />
<slider cc="64" name="pitch DECK2" deck="2" />
<button note="3" name="browser_folder DECK1" deck="1" />
<button note="52" name="browser_folder DECK2" deck="2" />
<button note="17" name="select DECK1" deck="1" />
<button note="24" name="select DECK2" deck="2" />
<button note="7" name="mix_now_nosync DECK1" deck="1" />
<button note="56" name="mix_now_nosync DECK2" deck="2" />
<slider cc="67" name="volume DECK1" deck="1" />
<slider cc="66" name="volume DECK2" deck="2" />
<slider cc="72" name="gain DECK1" deck="1" />
<slider cc="75" name="gain DECK2" deck="2" />
</device>
</device>
Posted Sun 20 Mar 11 @ 9:35 am
