I have recently downloaded a track into the cache folder from net search but i cant find the track on vdj6.....when i look via my computer i see the file in there but not in vdj so i cant play the track???
Posted Fri 07 Aug 09 @ 5:39 pm
hmmm
Posted Fri 07 Aug 09 @ 6:07 pm
Write again on the "Net"search bar the exact name of the track you download before... then just click on the name on the result list and click the "download to vdj cache" option again, that would be all, and relax you are not going to download it again that just going to fix your problem, i found that there is an issue with the option "refresh vdj cache authorizations".
Best regards..
Best regards..
Posted Fri 07 Aug 09 @ 7:32 pm
Ok i have entered it again and noe the tune has dissapeared off the face of the earth...???
Posted Sat 08 Aug 09 @ 4:25 am
did you "add to search db"? If not look on the far left of the browser and right click on "net seaech" and choose "add to search db". After doing this you should be able to see your net search files when performing a search in the search box.
Posted Sat 08 Aug 09 @ 1:35 pm
