Just encountered a problem with my RMX and VDJ.
When mixing deck B into deck A, the beats on deck B suddenly automatically alligned themselves to the beats on deck A.
The jog wheel rendered itself inactive and I couldnt move Deck B away from its alligned position.
I could stop the track but when i pressed play to restart, if off beat, the software would slow down deck B for half a beat to allign itself back onto the beat of deck A. Still no use from the jog wheel.
The only way I could get out of this alligned position was by restarting VDJ.
Have I done something stupid here and inadvertently selected some kind of function to automatically mix the two decks? I'm worried i've discovered a bug, not good as I have a gig this weekend and was practising a set when this happened.
Rich
Rich
Posted Wed 05 Aug 09 @ 1:58 pm
Hi,
Next time this happens try hitting your "B" key on the keyboard. Sounds like you have Beatlock engaged.
jkl
jkl
Posted Wed 05 Aug 09 @ 2:01 pm
JimmyL-DJ wrote :
Hi,
jkl
jkl
Jkl
got it cheers. think this is what the problem is.
is beatlock (b shortcut) different to the beatlock on the RMX then? I thought beatlock on the RMX was to hold the key of the track not physically lock the beats together?
Posted Wed 05 Aug 09 @ 2:06 pm
