Hey Guys,
So i finally got around to trying the timecodes out on VDJ for the first time and I must say it was nice, but the latency seemed horrible. I watched a setup video on youtube and it was good for getting everything working, but the latency was just not there. I had everything up and running, but if i were to catch a beat at like....9 o clock on the record it would be behind at about 12 o clock it seems like the timecodes were just not responsive like they should be. Is there a certain setting I am missing, or is VDJ just still just not that great for timecodes? Would appreciate any input possible, thanks guys.
Posted Mon 03 Aug 09 @ 8:41 pm
Sorry mate,
i'm not so good in timecode+ RMX as i should, but I see you post has no answer, so …. XD
VDJ is perfect for timecode, but as far as i know the RMX integrated soundcard is not the best for timecode.
I see you have the VV soundcard!
The VV Soundcard is much better then the RMX soundcard.
Use this one and the RMX as a mixer and i believe it works pretty well.
My position ;-)
But on the other hand, it is possible you have only the wrong settings inside.
Do you use the latest driver for the RMX?
Whats your VDJ performance setting and did you use in both (RMX & VDJ) configs ASIO?
I'm sure, more responses will come ;-)
Haui
My position ;-)
Haui
Posted Thu 06 Aug 09 @ 1:52 am
