so basically when i load up a song from an album it only loads up the first say 20 seconds. when i play the song it will then load it up but only 20 seconds from where it is in the song and i have 2 listen 2 the song before it is fully loaded? if that makes sense?
this doesnt happen on all of my songs but it does happen on alot and alot from the same albums etc.
any help would be great.
cheers
cheers
Posted Tue 28 Jul 09 @ 6:19 pm
I'd check max load in your settings tab...change it to 15 mins or more and try again.
Also...what kind of files does this happen with?
And finally...what are your PC specs too?
Keep spinnin'...(",)
P
P
Posted Tue 28 Jul 09 @ 7:14 pm
hey!
ok i got it working for now.
what i did was changed the max load to 30 min as it was allready at 15.
i also changed allow (allow BPM<80) to smart? dont know if that made any differance but it works now :)
cheers for the reply, much appreciated!
Posted Wed 29 Jul 09 @ 6:17 am
Well, the main thing is that you got it sorted...(",)
Happy to help.
P
Happy to help.
P
Posted Wed 29 Jul 09 @ 5:49 pm
