Well I'm going to purchase a RMX as I like the portability aspect & seems to be working well for most of you that have one. Will still use my Denon HC4500 as well, but some nights I have multiple gigs & would like to be able to let my guys use the Denon.
The only question I have is: Can I run time code vinyl thru the RMX with VDJ? Not that it is a major thing if I can't, but would be great to be able to do that at home.
Thanks!
Cheers!
Thanks!
Cheers!
Posted Mon 27 Jul 09 @ 3:54 pm
Yes you can, although I haven't tried it.
Check this thread out, it may interest you
https://virtualdj.com/forums/113004/Hardware_Technical_Support/Virtual_DJ___Time_Coded_Vinyl___Hercules_RMX__Setup_Tutorial.html
Posted Mon 27 Jul 09 @ 4:45 pm
Thanks Jimmy!
Posted Mon 27 Jul 09 @ 5:41 pm
