Topic: Need Some Help!!!!!!!!!!!!
I had downloaded the trial version of VDJ v6.0 about a week ago and one thing I have noticed when trying to play around it is that I can't assign two shortcut action to one key on the keyboard as the case in the previous editions. Example, assigning "play" and four beat loop" to the F2 key so that as soon as I press the F2 key my deck will start playing and loop 4 beats. I don't actually know whether I was doing the right thing. But if that feature has been removed in the v6.0, then it is not good. Atomix Production should try and bring this feature back. It is very important. I hope somebody can help me out, though I'm just a no license user. I've been trying unsuccessfully over the years to raise some money to buy the full version of VDJ Pro. But I have the belief that one day in this forum, I will acquire the pro version user status.
DJ Monarch!!!!!!!!!
Jubilee Radio, Keta, Ghana
Posted Mon 27 Jul 09 @ 9:38 am
it is not gone, it's still here, and even more simpler
you should take some time reading the forums, at least the sticked posts
here it is
play & loop 4
Thanks DJ Erdi. I'll go home to try that. Cos now I'm at work.
But if I get you clearly, it means I have to combine two actions with the '&' and those two actions will apply? What about three different actions on the same key? Please help
Thanks so much once again!!!!!!!!!!!!!!!!!!!!!!!
You can apply as many as you like by using & in between each action.
Thanks so much DJ jpboggis for the quick response. I did it as said by dj erdi and I'm so happy it works great. Thanks to the VDJ production team. Its only that I'm trying hard to make an ends meat as I'm coming from the other side of the world - where things are different - Africa. I like VDJ so much but I can't afford the price quoted for it. I hope one day, one day I will be a professional edition user one day in my life.
Thanks everybody for the great work!!!!!!!!!!!!!!!!!!
Dj Monarch, Jubilee Radio
Keta.
best of luck to you and hope you get your wish granted soon.
If you are just using your computer to mix without a MIDI controller or timecode, you could always start off with VirtualDJ Home Edition, which is only $49: https://virtualdj.com/products/homeedition.html
A Hercules DJ Console is another good option - Everything you need in one package, including free VirtualDJ Console Edition.
I really like the Hercules DJ Console. How much does it cost? And considering where I'm coming from - Ghana, will it cost me more than $300 to import it? Please give your advice
