Doing a party and it seems like every song skipped? Any ideas? Also had some fuzz sounds coming from the speakers? These things have never happeend before. Using rmx console amp. Any help appreciated
Posted Sat 25 Jul 09 @ 6:58 pm
Yes, the music is too loud and you are vibrating your RMX. No, you don't have to turn down the music, you need to take the RMX out of "Scratch" mode, then this won't happen. You may want to buy a rubber mat to put underneath your unit to help dampen vibrations.
I know this bit of info not because I own an RMX, but because my good friend DJ Advise has encountered this. One of sons owns an RMX too and he asked me the same question.
Try it.
DJ RuDe
Try it.
DJ RuDe
Posted Sat 25 Jul 09 @ 7:03 pm
Thanks for the reply it seems I don't have the scratch button enabled. Also my rmx is rack mounted any other ideas? Appreciate it
Posted Sat 25 Jul 09 @ 7:08 pm
I'm not sure, that was just my first thought.
DJ Advise, were are you!? He's the RMX Guru
Posted Sat 25 Jul 09 @ 7:22 pm
Some info on the RMX by DJ Advise
Posted Sat 25 Jul 09 @ 7:26 pm
