Even with the canopy., the glare from the sun can make it hard to see. What i usually do in those situations is to switch to the Hercules RMX skin. everything is much more visible
Posted Sun 26 Jul 09 @ 10:39 am
This is what I use. It was a great investment.
We bought this tent here http://www.advertisingballoons.com/
Good Luck,
Keivan
Good Luck,
Keivan
Posted Sun 26 Jul 09 @ 12:45 pm
nice bit of kit
Posted Sun 26 Jul 09 @ 2:30 pm
Rudd Dog wrote :
Your tent needs to be anchored
Don't worry Rudd Dog I have seen plenty of tents get away from their masters. The tent in that picture is actually anchored to the ground with cork screw stakes. I use a piece of rebar twist them into the ground. If the photo was a higher resolution you would be able to see them better.
Posted Mon 27 Jul 09 @ 3:01 pm
Ha ha, OK that's good! I wouldn't want to see the "after" pic if a gust took it away!!
The "Preferred DJ's" Canopy is similar to mine except it doesn't have my company name and logo. Mine was purchased from Costco and it's white and blue. BTW I like it and may look into getting one done like that, though I don't do a ton of outside gigs. Very nice!!
DJ RuDe
Posted Mon 27 Jul 09 @ 4:12 pm
