Tried to get some info on a different thread but believe the thread is not being looked at any more so I started this one .
I was about to go shopping for a sound card Maya 44 then was advised that the M-Audio Conectiv is better. Since then several others are possible options. So could you please assist me in making the best choice for my set up (VDJ 6.0.1 to Pioneer DJM 800 & CDJ 1000 MK3's)?
-M-Audio Conectiv?
-Maya 44?
-Vestax VAI-80 (aka Little Tank)?
-other choices?
Thank you!
-M-Audio Conectiv?
-Maya 44?
-other choices?
Thank you!
Posted Fri 17 Jul 09 @ 11:07 pm
The M-Audio is probably your best bet. Native Instruments Audio 8 DJ sound card is another choice, Click to review...
Sorry we couln't be more specific and offer more insight.
Good luck...
DJ RuDe
Good luck...
DJ RuDe
Posted Sun 19 Jul 09 @ 2:50 am
The M-Audio Connectiv is a very good sound card
Posted Sun 19 Jul 09 @ 8:38 pm
I have a 192L Waveterminal from ESI.
It seems to 'growl' when running ASIO and tempo change. WDM not much better. VERY fast system configuration.
I like the 8 ch output feature.
Will try my Gigaport HD and see how that works.
Posted Sun 19 Jul 09 @ 9:22 pm
+1
Syberman
Posted Sun 19 Jul 09 @ 10:11 pm
Thanks to all!! Shopping time.
Posted Sun 19 Jul 09 @ 10:16 pm
