Been using VDJ for 2 yrs and love it. Just upgraded to RMX and vdj 6. everything seems to work great but every song played has a slight drop out every 20 seconds or so. could it be a buffer or ram issue? please help ty!
Posted Fri 17 Jul 09 @ 10:03 pm
Have you installed the very latest drivers for the RMX yet?
Posted Fri 17 Jul 09 @ 11:09 pm
just bought the RMX Controller it came with software loaded it and then upgrated to VDJ - 6. I now have it working on VISTA are there newer drivers for the VDJ 6 / could that be the problem? Everything seems to be working EXCELLENT on the RMX, it sounds great but every song seems to have a split second audio drop about 25 seconds in and then through the song.
Have some big shows coming up really need to get the sound in place.
Thanks For The Help
Thanks For The Help
Posted Sat 18 Jul 09 @ 5:50 pm
Go to Hercules technical support driver download and get the latest drivers for the RMX. If this doesn't work, try increasing your ASIO latency in RMX control panel.
Posted Sat 18 Jul 09 @ 9:33 pm
Thanks, I'll try it and let you know what happens.
Posted Sun 19 Jul 09 @ 8:42 am
I'll await your results ;)
Posted Mon 20 Jul 09 @ 11:57 pm
Thanks, the update from Hercules helped, I also increased the ram to 2048. I'm very impressed with this new version of VDJ, I'd like it to be running it's best. My latency is on auto in VDJ should I change it, how might that help?
Thanks so much for your help!!
Posted Sun 26 Jul 09 @ 12:03 pm
VirtualDJ config>Performance tab, set
Preset slider to "Fastest" Latency on Auto and uncheck Safe Mode and Overclocked.
You should be good to go with that
P.S.
Disable your WIFI/Bluetooth adapter in Device Manager. It's a known cause of Audio drop outs.
Posted Sun 26 Jul 09 @ 12:48 pm
Thanks Again, I'll give it a try. In the performance screen I see a tab next to latency which gives me the option to select auto or one of the bits 32 - 64 etc, above that is the slider for fastest or best quality. I will adjust the slider to fastest, should I leave the other tab on auto?
I'll also disable the bluetooth and wi-fi.
I am very impressed with this version of VDJ, hopefully I can straighten out this audio problem, I appreciate the support!!!
PS Jimmy B Are you from New England, USA
Posted Sun 26 Jul 09 @ 11:36 pm
Is the buffer easy to adjust, that's what it sounds like to me Jim, I've also notice that the songs seem to take a long time to load. The last version was alot quicker, I have a double gig on Friday and hope everything works well? I'll do all the stuff you've guy's told me so far, my last version was perfect, used a MK-2, hp laptop 1024ram with an AMD 64. The VDJ program was 5.0 pro I beleave, the version before this one, did Weddings, Schools, Karaoke and some very important events. I can see alot of Nice improvements with the new version do you think I can get it to run as smooth as my other version?
PS Jimmy, my niece is living in Manchester, thanks again for your help!!
Are you one of the Tech's and did you help write this program?
Posted Wed 29 Jul 09 @ 12:13 am
No mate, I don't have a clue about programming and I would no where to start either. I just find I pick things up easy if I mess around with stuff. For me it's the best way to learn.
The ASIO Buffer is easy to change. Once your RMX is connect and before you open VirtualDJ up. Open the RMX control panel (DJ Icon near on Tool bar)
Go to the ASIO tab, click on the ASIO dot if the settings are shaded. The last option is ASIO BUFFER SIZE. Click on the drop down and choose the next sample rate down from the one you have been using. If that doesn't get rid of your audio pops then keep changing it till it does.
As for your slow loading try doing a Disk clean up and defrag on all your drive's before you gig. This will certainly help your systems performance, and may speed up loading times. Also could you put your RMX serial number (found on the software CD sleeve) in the "Modify my profile" and you will get the RMX icon under your forum name.
Hope all this helps mate.
Posted Wed 29 Jul 09 @ 3:39 am
Thanks Jimmy, I'll work on getting rid of that pop with your help. Have a bunch of Gig's this weekend and will get back to you on Monday with an update.
Thanks again, you've been very helpful
Posted Thu 30 Jul 09 @ 11:45 pm
Hi Jimmy,
Had major problem and late start to show, when I opened ASIO I clicked to next buffer setting during first show. It seemed a little better, then for the second show, after openning ASIO noticed it was on the WMA side (what is the differance) so I changed it back to ASIO and then went one or two more on the buffer and then in advanced settings it had an X for the bottom choice but I use a MIC and selected channels 1 & 2 w/Mic. That was when my problems started VDJ partially opened and a error for ASIO drivers came up and could get controller to operate. I restarted and then finally shut off unpluged for a minute and was able to function but the skip is worst? AOl seems to Exc everytime I open VDJ, I've changed the settings in VDJ but it still keeps openning.
ps both times I changed settings before openning VDJ
Posted Fri 31 Jul 09 @ 11:06 pm
you are having problems with the soundcard and the operating system not cooperating with each other
do all of the following ......
turn off windows firewall
set your power options profile to " always on" and then set all the options below that to "never"
in device manager diasable wifi , bluetooth
set screensaver to none
defragment all your drives esp the C: and the drive with yer music , which if you 're smart is an external drive
check in task manager to see how many background processes you have running , you want to be below 50 , and you can get much lower than that this is done by turning off these unneeded items.........
make sure you are set to asio
Posted Sat 01 Aug 09 @ 12:26 pm
Guys Thanks abunch, I tried a few differant thinks, 1 went into device man, disabled DVD CD rom drive, Disabbled as many wi-fi and wireless cards I could find. had a bad crash during gig but while VDJ was playing it sounded better some loads where quicker also.
I uninstalled all the AOL and diabled all updates and will look at that video card setting. also defraging everything right now.
Hope to resolve theses problem and get back to enjoying my smooth VDJ!!! I can see all the improvements but need to start sounding perfect again
ps what happened to night after crash when restarting VDJ would come to boot screen stop and a error ASIO box then it woud freeze.
I'd have to shut down and then start again, restart wasn't helping
Posted Sun 02 Aug 09 @ 12:57 am
ps I will try to put all your help to work and let you know my progress, along with what seems to be happening.
Thanks for taking your time to help me, my VDJ 5 & MK 2 with my HP laptop never had any problems, besides my first Dennon and my Pioneer 500G's I thougt this was the best on the market, when it's running smooth it's nice
Posted Sun 02 Aug 09 @ 1:10 am
Today was a turn around, that checked box in set-up might have been the direct problem and disabling all them devices really helped.
Thanks so much for helping!!!
Little off subject but would anybody know the best way to get my karaoke CD-g discs onto a hard drive? Haven't had any luck with any programs.
Posted Mon 03 Aug 09 @ 12:22 am
Audiograbber
Posted Mon 03 Aug 09 @ 12:24 am
my problem is with the graffics, will that program load the whole file so I can get the words on the screen. If I put a disc in the computer it doesn't seem to see the words
Posted Mon 03 Aug 09 @ 1:53 am
