I had registered my serial at Hercules (when installing my RMX).
Now when I go to put in my serial here... it says it's already registered.
What do I do?
What do I do?
Posted Fri 17 Jul 09 @ 7:55 pm
Contact the seller you purchased the RMX from.
Posted Fri 17 Jul 09 @ 8:16 pm
You think the Serial has been already used?
Whats even more weird is...
the example of the serial to input on the Virtual DJ is XXX-XXX-XXXX (3,3,4)
Yet my number is more like XXXX-XXXX-XXXXX (4,4,5)
Posted Fri 17 Jul 09 @ 8:30 pm
It could have been purchased and registered and returned, that has happened before. The other option is, you need to register the software CD serial number, not the hardware serial number.
Posted Fri 17 Jul 09 @ 8:37 pm
Hmm.. now that I think about it.
The Hercules site didn't require any serials.
Now this sounds really fishy.
Posted Fri 17 Jul 09 @ 8:45 pm
