hi there recently bough the hercueles mk 2 console and i was jst wondering for when i am playing gigs as my amp is now broke can i use this directly to the main speaks and connect the hercueles mk 2 console via my laptop with the audio wire i am using instead of connect the wire to the amp then my hercueles mk 2 console ..
is it poss just to link it to the output ports and then directly to the laptop and the speaker commin from the port at the back of the hercueles mk 2 console so then for i would no loner need my amp
Posted Thu 16 Jul 09 @ 5:31 am
simply put no.
if your a "gigging" dj spend some of your hard earned money and get your amp fixed.
Posted Thu 16 Jul 09 @ 5:44 am
only if you have powered speakers otherwise you are going to need a fixed or new amp.
Posted Thu 16 Jul 09 @ 5:48 am
always have a spare Behringer 1500 watt amp
they work and are very cheap. either used or new.
Posted Thu 16 Jul 09 @ 8:53 pm
Yep - the MK2 is not an amp, just a soundcard. Like Tayla says, unless you're using powered speakers (you mentioned a broken amp, so that's not likely), you must have an amp connected to run your system's speakers.
Posted Thu 16 Jul 09 @ 8:57 pm
????? I would think you would still need an AMP, unless you have powered speakers?? No matter what, how are your speakers going to work with out an AMP??
Posted Fri 17 Jul 09 @ 1:03 am
Oh, I thought the mk2 was 750w p/c
Posted Fri 17 Jul 09 @ 12:17 pm
