Here's what's going on:
When i start up the program, if i use the left player first, the audio comes out all "garbled". But if i use the right player first, then both sides work fine. Now i'm still new to this program and haven't taken the leap of using it on a wedding yet. Any ideas?
Thanks
Thanks
Posted Tue 14 Jul 09 @ 4:02 pm
This is a new one on me...What version are you using, and what are your performance settings?
Posted Tue 14 Jul 09 @ 4:22 pm
I'm using 6.01, i'm my setting are set for fast over quality.
Posted Tue 14 Jul 09 @ 9:37 pm
Hi, are you using any controller or timecodes?
What soundcard are you using and system specs?
Posted Tue 14 Jul 09 @ 9:38 pm
