New problem. I will be playing a song on one deck. As soon as I cue up and start playing the song on the second deck both decks will react with a strange, digital sounding noise distorting the music. Just popped up out of nowhere. Any ideas??? This is happening using VV.
TCV config shows everything is fine. 100% signal. I turned the gain down in case the music was over modulating in the system. Didn't fix anything. Help???
VDJ 5.2.1 Pro
VV interface box
Technics 1200 MK2 (Two) running new M-44-7's
Windows XP
1 GB Ram
Lenovo Laptop
Denon X120 Mixer
VDJ 5.2.1 Pro
VV interface box
Windows XP
1 GB Ram
Lenovo Laptop
Denon X120 Mixer
Posted Mon 13 Jul 09 @ 7:04 pm
Interesting update to my problem with the noise. It only happens in VDJ. It does NOT happen when I use Numark Virtual Vinyl Program.
Posted Mon 13 Jul 09 @ 7:35 pm
Problem solved. It was the Key Lock function. I forgot I had activated it while doing some checking on some stuff. I had to set my Pitch Sensitivity and Lead time to Zero to cure a BPM drifting problem and apparently now I can not use the Key Lock function anymore.
Posted Mon 13 Jul 09 @ 7:51 pm
