Hey sup guys I have a simillar problem to what this person experienced: https://virtualdj.com/forums/96818/Hardware_Technical_Support/SL-1_Box_is_Not_Showing_up_in_Virtual_DJ.html
but his question was left unanswered.
So I have a 64-bit Vista OS and there when I attempt to locate the SL-1 sound card from the list in the configuration menu (I have 5.2 Pro by the way), it doesn't appear. I have installed the 64-bit drivers for the SL-1 and I still can't seem to get it from the list. I'd appreciate it if you guys could help me.
Posted Sat 11 Jul 09 @ 7:45 pm
SL1 won't show up? Have you set the output to MIXER then select ASIO or SL-1 in the bottom (3 of 3 main choices [input, output, output way])? If not, try VDJ 6?
OR!
Set it to ASIO and inside the ASIO config, set it to SL-1
OR!
Posted Sun 12 Jul 09 @ 1:57 am
