Ive had Virtual dj for about 3 months now and have not yet been able to use it with the timecodes.. When I plug it in and mix with the mixer and mouse it works perfect. When I set it up to use it with timecode cds it works like its suppose to but the songs make like a burp sound or skip. What can I do to fix this???
Posted Thu 09 Jul 09 @ 7:53 pm
Sorry your having trouble. Help everyone here to help you. Please list your PC specifications, your type of sound card, your version of VDJ and the type of players your using. Please be as specific as possible.
Posted Thu 09 Jul 09 @ 8:26 pm
Yes give us as much info on ALL your equipment as you can.
Posted Thu 09 Jul 09 @ 8:40 pm
ok lets see if this helps any.. I have a Dell 1420 windows xp pro version 2002 service pack 3.. intel pentium dual cpu T2330 @ 1.60 ghz 2 gigs of ram and 160 gigs hard drive.. sound card looks like sigma tel audio and im using denons dns 3500 with a behringer mixer djx 700.. Did that help any?
Posted Fri 10 Jul 09 @ 2:00 pm
oh and I have vdj version 5.2.1 pro
Posted Fri 10 Jul 09 @ 2:02 pm
its numark virtual vinyl version 5.2.1 pro... sorry I have vdj as well but I use the virtual vinyl..
Posted Fri 10 Jul 09 @ 2:04 pm
Any word?
Posted Mon 13 Jul 09 @ 3:43 pm
that's a default system card ...........!!??
turn off wifi and bluetooth in your device mgr
whatever the system priority is set at (either programs or background processes) switch it to the other setting
turn off windows firewall
set your power profile to always on then all the boxes under that to "never"
turn off all your system sounds ...............
Posted Mon 13 Jul 09 @ 7:29 pm
you need a real soundcard
those tweaks i suggested are good , but there are many others that might be needed
defrag , then defrag again
eliminate processes and try to get the number down to 40 or less
update yer active x
update yer active x
Posted Mon 13 Jul 09 @ 8:04 pm
Thanks for the help Ill give it a try.. What kind of sound card to you recommend...
Posted Tue 14 Jul 09 @ 8:36 am
