I created a new user profile on my laptop and tried to install VDJ there but I keep getting the "installation error" after inserting my serial number. I went in to msconfig and disabled nod32 before doing the install and removed VDJ from the other profile. Originally i tried to copy the shortcut from the other desktop but that actually gave me the same error. i tried uninstalling and reinstalling but same error. Any help would be appreciated.
Funkmasterfrank
Funkmasterfrank
Posted Thu 09 Jul 09 @ 12:11 pm
try using a final uninstaller of registry cleaner..then re install.. chances are there is a registry key that is causing the error. clear out the previous installations completley before trying to reinstall.
if there is aregistry entry from a failed installation or maybe even a .tmp file then there is a good chance thats what it is..
on that note clean out your temp folders too.
Posted Thu 09 Jul 09 @ 12:32 pm
The problem is due to NOD32 which prevents VirtualDJ from installing itself correctly.
Posted Thu 09 Jul 09 @ 1:01 pm
why would people use an antivirus that blocks the installation of softwares???? to me it seems like a pointless activity to use an antivirus that cant recognise a legit installation process. get yourselves AVIRA it works so much better.
Posted Thu 09 Jul 09 @ 1:34 pm
I did what the "non licensed user" suggested and it installed fine after that.
Cstoll... I already said in my 1st post that I turned off nod32 before installing. I knew this from a past installation, that's why I mentioned it in my 1st post that is was off.
"non licensed user", I use nod32 on my lappy because every other anti-virus I tried over the years slowed down my computer too much. I have been using Nod32 for a long time and you wouldn't know it's running in the background at all.
Thanks for everyones help.
Funkmasterfrank
Funkmasterfrank
Posted Thu 09 Jul 09 @ 2:31 pm
glad i could help "experienced pro user" lol..
if nod is working for you then thats great..i just prefer to use avira as its free and has been the best AV ive ever found. and believe me ive tried a lot of AV's..
oh just one other thing...you can call me blu or blulite if you want.. i do have a liscence!!!! well sorta..
it was just registered by someone else...i purchased a used herc and software and the guy had already registered the liscence..so im just saving for an upgrade...just my luck to be honest.. origional software and no registration :(
Posted Thu 09 Jul 09 @ 5:30 pm
Never mind Bluelite. lol. What registry cleaner do you recommend to use BlueLite ? there are a lot on the net and I don't want to just get some random one.
Posted Tue 29 Sep 09 @ 3:51 pm
the registy tweak utility on the vdj downloads pages can be used to remove all the registry keys for vdj.
you need to log into windows using the old name, and run the utility.
Posted Tue 29 Sep 09 @ 9:00 pm
Did everything you mentioned. Got Avira and Zone Alarm - everything off. InernetConnection is alive.
Deinstalled VDJ, Made a Registry Cleanup with the tool from the download-page, reinstalled it and again there was the error. Any help? Opened a help-ticket here - but cant believe this is happening. Tonight i got a gig - thats a real problem :( :( :(
Posted Wed 30 Sep 09 @ 9:45 am
hey elcheffe87, did you find a solution? I have the same error and tried everything what was suggested on this page.
Posted Tue 10 Nov 09 @ 2:21 pm
