Hello everybody!
I have recently installed virtual DJ and have been working with it with no problems... til about two days ago.
Software opens and loads music without problems. The surprise comes when I try to add any sound effect to any song. When I select any sound effect (e.g. flanger) it makes a pop noise within the song. Moreso, when I adjust parameters such as "volume" "strenght" or "delays" of ANY type of sound effects, it makes a horrendous noise all the time I am dragging the levels.
Very oddly, actions like scratch (from the turntalbles), picth adjustments, volume settings, mixer crossfades work perfectly. No problems being reflected on that area...
What could the issue be?
Should I try uninstalilng it?
My PC has a Creative Sound Blaster Audio PCI
The strangest thing is that when I stated operating the software it didn't render any problem at all...
Help will be greatly appreciated!
Cesar
Cesar
Posted Sat 04 Jul 09 @ 9:38 pm
If you have received any 'Auto Updates' for your operating system then a file may have changed that is causing the problem. Reload your sound card drivers using the manufactures drivers ... see if that fixes the issue.
Posted Tue 07 Jul 09 @ 6:49 pm
