Ive just downloaded a karaoke file from itunes and i now need to convert it from m4v to cd+g. Can it be done and if so, Does anyone know of a bit of software that will do this? regards, Rob.
Posted Thu 02 Jul 09 @ 4:59 pm
Question, why do u need to convert it?? M4V will play in VDJ as long as its an ITunes Plus file.
Posted Thu 02 Jul 09 @ 8:09 pm
it plays the music ok but im not getting the words up on the screen.
Posted Mon 06 Jul 09 @ 4:38 am
Ok Ive found the problem. I contacted itunes and they have refunded me because their karaoke tracks DO NOT DISPLAY LYRICS! Perhaps they should title these backing tracks or instrumentals but certainly not karaoke. If you do want to buy download karaoke files, i recommend these people. http://BuyKaraokeDownLoads.com/ Its like itunes for karaoke except they actually work. :)
Posted Sat 29 Aug 09 @ 9:01 am
There's always the hard (but free) way to do it: If you already have the instrumental, get a CDG creator software and sync the lyrics by yourself.
Posted Mon 31 Aug 09 @ 1:33 pm
Rob, the best way I have found for karaoke is the same good old fashioned way. Buy CDG discs and rip them. I get all of the latest from Sunfly, Sound Choice, Chartbuster and others, rip them to my external drive and shelve the discs in my CD/CDG/DVD/HD DVD/BlueRay library. I haven't attempted to buy pre-ripped formats online. Last time I did that there were problems with the files. Besides, I like having my backups.
DJ RuDe
Keep Spinnin'!!
DJ RuDe
Keep Spinnin'!!
Posted Mon 31 Aug 09 @ 3:23 pm
